Facebook Twitter RSS MPORA
BOS Engineering: Stoy & Idylle
BOS Engineering has come in swinging to the high-end consumer market with a downhill shock and a downhill fork. Rough translation inside. Available soon. English page is also now available here with details.
S** Toy (Stoy) Rear Shock
BOS Stoy (Sex Toy) Rear Shock
Successor of the DH07, Stoy is the new damper BOS descent. Even more successful than its predecessor, it is changing especially in the design. It will be using a new head piggy-back, and a shorter tank. The entire block compression adjuster is also completely new. Finally, Stoy receives mounting rings bearing needles, a luxury previously reserved only for shock absorbers “factory” for Nicolas Vouilloz. Advantages of the system: a game reduced to nothing, and a very long lifetime compared to the du-bushing usually used.
Like all BOS dampers, Stoy is fully adjustable and rebuildable.
Available for most bikes down the market, in the usual standard lengths, it may also be delivered in extras and race one-off sizes upon request.
BOS also uses springs in 25lb increments to also aid in dialing in the perfect spring.
Features:
  • Shocks single hydraulic valve type 3 lanes
  • Settings; compression slow / fast compression / rebound
  • Completely rebuildable
  • Setting main “tailor-made”
  • Aluminium Head, housing guide, cylinder, and preload nut foot aluminum
  • Shaft Ø 12 mm
  • Optional mounting kit needle roller
Idylle Front Fork
  • Independent Hi/Low compression, and rebound
  • 6061 crowns
  • Magnesium lowers
  • Similar parts used with the Stoy
  • 36mm stanchions
  • 200mm travel
  • Postmount brake tabls
  • 20mm axle
BOS Idylle Pro Fork
BOS Idylle Pro Fork
17 Comments
    S** Toy = Sex Toy!? Really? Thats pretty cool! I guess French humor is an acquired taste…
  • The stuff looks really good though! Interesting to see there is no direct mount top clamp… a little disappointing, but I’m sure it wont be long before this is offered. Finally to have a fork that can match the rear end! *DROOL*
  • Nice…. when do we expect to see one in USA?
  • It should be available in about a month. They’re working on a distributor in the USA. I know you’re itching to try one out :)
  • weight?
  • Le Sex Toy……ahhhhhhhhhhhh
  • They look a bit like the Kowa / MSC forks. Are these Kowa forks with BOS internals?….
  • si c est un sex toy je veux le meme pour ma copine!!!!!!! mdr
    Très drôle!
  • Hey Andre!
    You learnt a litttle bit more about french humour last winter, didn’t you? :D
    If only you could understand what golem said…
    Nice stuff!! Looking forward to see it with my own eyes!
    Fab (frenchie)
  • any idea on pricing for those bad boys?
  • Frenchie! I want the same toy for my “copine” too!
    j’apprends
  • weight, price….
  • Price are still being finalized. Will post up more info when i get it.
  • that fork looks even better on a bike than i thought… mmmn! nice!
  • where can i find this fork in Boston city? did you have any distribuitor?
