New Hayes 2008 Brakes: Stroker Gram and the Stroker Ace
Hayes has got two new brakes this year called the Stroker Gram, and the Stroker Ace. Check out some of the details inside.
2008 STROKER ACE
- LIGHTWEIGHT DH/FR PLATFORM
- Stoker master cylinder
- Longer lever with aggressive hook and increased mechanical advantage
- Indexed reach adjustment dial
- Four-piston, forged mono-block caliper
- Sintered and semi met pads available
- Fits 6, 7, 8, and 9†rotors
- System weight: <440grams (6†post mount with steel mount hardware)
2008 STROKER GRAM
- LIGHTWEIGHT XC/AM PLATFORM
- Weight-reduced Stroker master cylinder
- Carbon fiber brake lever
- Two-piece forged caliper
- Ti bridge bolts
- Semi-met pads with alloy backing plate
- 5″ (rear only), 6, 7, 8, and 9″ rotors available
- System weight: <350grams (6†post mount with Ti hardware)
Expect to see more about these new brakes at Sea-Otter this year.
