Facebook Twitter RSS MPORA
Preview: 2008 Formula ONE Disc Brakes
Formula has answered many riders’ requests and now have some new brakes that are aimed at the more gravity enthused. The Puro/Bianco series are some of the best brakes money can buy and I’ve been impressed with them since I started using them. The two new brakes, The ONE, and The Mega share some similarities but we’ll be focusing on the ONE’s inside.
The ONE is a very lightweight brake aimed at the DH/FR/Gravity market but due to its overall weight, can be used in XC/AM category just as easily for those wanting the benefits behind the ONE.
The ONE brakes are completely overhauled and now feature a monoblock body for increased stiffness and lighter weight. The banjo bolt no longer goes through the whole caliper and there is increased fluid capacity to help make brake fade a thing of the past. The entire caliper is sleek and trimmed up quite nicely.
The ONE uses two 24mm pistons and they have a little bit less aggressive lever feel in terms of initial pull that most would describe as having “more modulation” than the Puro series does. More pistons doesn’t equal more power and these are currently some of the most powerful brakes out there that you can get. The ONE uses bigger sintered pads than the Bianco’s and maintain top loading pad insertion which enables you to change the pads without removing the wheel.
(click to enlarge
Bianco pad in the center with ONE sintered pads on the sides (click to enlarge)
Formula has some of the lightest rotors out there that still perform with the best of them and now they also have a 180mm Boxxer adapter as well as a variety of other rotors and adapters from 160mm to 220mm.
(left to right) Boxxer 180, Boxxer 200, Formula IS (click to enlarge)
The lever is redesigned and improved. The ONE is designed to have a breakaway lever that can hyper extend as well as a predetermined lever breaking point to make sure you can get down the hill should your lever break in a crash. Additionally they use a zero degree attachment making cutting the hose a bit easier as well as a redesigned master cylinder.
gold aluminium knob on the right is the throw adjust (FCS) (click to enlarge)
lever detail of engineered breaking point (click to enlarge)
The ONE features a tool free metal lever throw adjust (FCS) as well as a metal tool free reach adjuster on top of the lever. The lever feels like a hybrid of the Puro and the Bianco lever. You can use one or two fingers on these pretty easily.
tool free reach adjustment knob (click to enlarge)
Part Year Real(g) Pic.
Formula ONE Front Hose / Caliper / Lever (850mm) 2008 239
Formula ONE Rear Hose / Caliper / Lever (1500mm) 2008 252
Formula 180mm Rear Adapter (200mm IS front adapter) 2008 23
Formula 200mm Boxxer Adapter 2008 20
Formula 180mm Boxxer Adapter 2008 22
Formula 200mm Rotor 2008 181
Formula 180mm Rotor 2008 136
Formula Caliper/Mounting Bolts (x2) 2008 12
Formula Rotor Bolts (x6) 2008 13
The ONE’s truly offer downhill disc brake power at weights lower than most XC brakes.
We’ll be testing these brakes more in the near future but wanted to give you a heads up on some of the details of the new brakes beforehand. Formula has gained a lot of respect in the past year with their new line of brakes. Riders like Nicholas Vouilloz, Greg Minnaar, and Matti Lehikoinen all use Formula disc brakes for good reason. If you haven’t been lucky enough to try Formula brakes out, give them a try if you can, as the performance speaks for itself.
So there it is. The ONE has raised the bar pretty high. I wouldn’t doubt if we see more manufacturers trying to create a similar brake to compete but as it stands right now these are going to be very hard to beat.
Check out Formula-Brake.it and Formulabrakeusa.com for more info.
[Formula ONE Brake Gallery]
9 Comments
    do you plan to test magura louise?
  • We don’t plan on it unless Magura contacts us.
  • Anyone seen these for sale at a reasonable price?
  • http://www.chainreactioncycles.com
    Out of the UK, pretty decent price if you ask me. Free shipping too.
  • Those leverz are teh secks…
  • can you post a pic of the ONE pad next to a Hope Moto pad???
  • I find that Formula makes amazing products, its sad that not many bike shops outside of the US sells Formula, most sell Avid, Hayes, Hope and Magura.
    The ONE is a very interesting downhill brake which has the weight of XC disc brake. AM Riders would love to own the ONE and maybe some Trail Riders too. Racers would just go for Oro Puro.
    Lets hope its another great product by Formula, reviews are coming in and its a thumbs up.
  • So how do they compare with the new Saints you have tested. Which is the most powerful brake?
  • How do these compare to the Hayes Stroker Ace?
