Categories
News Submission
admin@sicklines.com
Support SickLines
Bike Build: 2008 Intense Socom FRO
Tuesday, January 1st, 2008
Welcome to 2008! First up, Intense Cycles hooked up this sweet Socom frame and we’ve got a killer build spec’ed for it in addition to a review down the road. The first person to guess closest to the final weight of this bike will win a prize so guess away (only one guess per person). It will most likely be a nice scale for you to use or a bike part. There’s some hints inside as well for you to ponder over as well as more pictures and details.
Hints for the build:
In 2007, Intense Cycles introduced the Socom FRO. The Socom FRO is designed to be a lightweight downhill frame that combines the strength of an Uzzi and the lightweight 6.6 into a downhill package. The Socom FRO’s geometry is downhill inspired and for 2008 they’ve improved this a bit more by slackening out the head angle a few other tweaks. FRO is “For Racing Only” but it still carries Intense’s 2 year warranty so rest assured it’s not a throw away frame that the name might imply.
The FRO badge isn’t meant as a daily bike necessarily but it does offer some additional strength over their standard offerings. They use weight optimized tubing (which doesn’t mean weaker necessarily) in addition to different weld specifications. Rick the welder expounded a bit more on the FRO techniques used and all tube junctions are double butted, or straight gauge. Similar to the Uzzi VPX, it is double welded at all joints. Like pipe welding, bead is applied on the inside as well as the outside.
Leave a weight guess in the comment field if you want to try and win the prize. Look for the complete buildup to be done in February.
[2008 Intense Socom FRO Frame Gallery] [Intense Cycles Website]
188 Responses to “Bike Build: 2008 Intense Socom FRO”
  1. cooper_xl Says:
    Hummm, 18kgs?
  2. laurent-charles Says:
    I guess 37 lbs
  3. dan Says:
    I guess 37.7
  4. dan Says:
    37.7 lbs
  5. Wouter Spanjaard Says:
    err.. around 40 lbs? Hope I win =D
  6. chad Says:
    38.46 lbs
  7. Jose Santiago III Says:
    36.8
  8. camdenthekid Says:
    37.6?
  9. Ben Says:
    37.15 lb
  10. Barry Says:
    im gonna say 37.9lbs
  11. Craig Says:
    39.2lbs
  12. Jack Says:
    36.4 lbs
  13. kyle Says:
    37.5 pounds
  14. Bl1nk Says:
    37.5
  15. booner Says:
    38.75 lbs
  16. ritter Says:
    I guess 16,6 kg / 36.59lbs
  17. Tmasi Says:
    17,6 Kg
  18. Rich Says:
    My guess is 36.5 lbs.
    What happened to the blindside build?
  19. S.K.C. Says:
    … I could post a guess or drop some hints, but Jason would have me killed in my sleep.
    I think you guys will really dig this bike once it’s completed. Very smart build.
    Cheers.
  20. sicklines Says:
    Rich, the blindside build will be out this month!
  21. Austin Says:
    I will say 37.4
  22. Evan Says:
    I think its 38.54 pounds
  23. nick13 Says:
    um 33.3 lbs
  24. nick freedman Says:
    39.5
  25. HJ Says:
    39.5lbs!!
  26. Matt Hofherr Says:
    37.34962 lbs
  27. nathan Says:
    35 pounds if done right
  28. Superdaver Says:
    14,5Kg / 31.96lbs
  29. Kellin the Melon Says:
    ~37.8lbs
  30. Sarge Says:
    36.8lbs
  31. Jason Says:
    35.8
  32. eric Says:
    36.3 lbs
  33. Todd C Says:
    I’m going with 37.14 lbs. If I’m right, Ben will most likely want me dead… =)
  34. Colin Says:
    37.87 lbs
    can’t wait to see this build!
  35. jordanmtbr Says:
    im guessing 37.8 lbs, could go silly light with xtr cranks if it hasnt got an 83mm bottom bracket, white bros or boxxer world cups, ti bits, easton wheels or something light like that…
  36. baxter Says:
    im betting 40 RC2 or weight equivalent
    38.37 lbs
  37. Oskar Says:
    34.36 lbs
  38. John Lee Says:
    36.9 lbs
  39. C Mac Says:
    36.06
  40. erik castillo Says:
    i guess the final weight will be 40lbs
  41. Sebastien Says:
    38.2 lbs
  42. John Says:
    37.35
  43. Justin Says:
    I’ll go for 37.5lbs
    Lord knows though!! It’ll be one hella build and I’ll suffer from jealousy for all of eternity.
  44. AiR Says:
    36.75 lbs
  45. tech Says:
    16.4 kg
  46. chober Says:
    36.76lbs
  47. ANDREW Says:
    38.76 lbs
  48. swampwolf Says:
    37,55 lbs
  49. Adam Says:
    34.5 lbs
  50. zndr Says:
    17.3 kg / 38.14lbs
  51. mehukatti Says:
    16.55kg / 36.48lbs
  52. jong Says:
    correction not 36.2 lbs
    my guess is 35.6lbs
  53. Patrick Says:
    I would guess 36.45 lbs.
    these are sick lightweight race frames..
  54. Elio Says:
    37.11 lbs
  55. Yeti Says:
    16.6kg or 36.59lbs
  56. Chris Allan Says:
    I reckon around 38.2lbs as a complete guess.
  57. Ricardo Silva Says:
    16,250 kg / 35.82lbs
  58. Brendan Says:
    ~37.64
  59. Tom Says:
    36.15
  60. Tom Says:
    36.15lbs
  61. exxodus Says:
    i’m thinking:
    boxxer WC
    thompson stem and post
    hope pro2 and Dt5.1
    17,100g +/-
  62. Jani Says:
    37.19 lbs
  63. Dreicha Says:
    17,0Kg / 37.48lbs
  64. Ross Says:
    39.25lbs
  65. Guy Says:
    16,6kg / 36.56lbs
  66. Johan Says:
    It will… weigh somewhere around 17.35 kilos!
    It’s a good skiing winter before an even better downhill summer!
  67. Dogboy Says:
    37.25lbs
  68. Arvin Says:
    39.6 pounds
  69. menace Says:
    16,75 kg / 36.92lbs
  70. winner Says:
    36.73
  71. plf Says:
    36.41 lbs
  72. Joz Says:
    37.038 lbs is my guess
  73. Chris Says:
    I’ll say 38.7 lbs.
  74. Cliff Josey Says:
    39.975 lbs.
  75. Andreas Says:
    16.58kg / 36.55lbs
  76. javan Says:
    38.564
  77. lorenz Says:
    17.35kg / 38.25lbs
  78. marcus wildman Says:
    38lbs too much less and it could get unreliably light!
  79. Rodrigo Vargas Says:
    38.22
  80. eren Says:
    37.13lb
  81. Colby Says:
    37 flat
  82. Jordan Says:
    34.21
  83. Mike Says:
    39.5
  84. simon Says:
    36.21 lbs
  85. westman Says:
    38,10lbs / 17,29 kg …
  86. Tomsk Says:
    36.44 lbs
  87. Aldo Says:
    36.75
    Sweeeet bike!
  88. Dave Says:
    I will say 37.73
  89. Andy Says:
    41.00 lbs
  90. Dean W Says:
    37.2 lbs
    But only if the metal shavings are taken out of the bb shell ;-)
  91. James Says:
    34.9
  92. James Says:
    …if they use Ti bolts like I did on mine!!
  93. Matt Says:
    37.55
  94. chad Says:
    um 36 flat?
  95. Laura Says:
    17,7Kg / 39.02lbs
  96. Kieran Says:
    36.7lbs
  97. Simon Says:
    35 lbs
  98. Biny Says:
    36.101lbs
  99. Scott Says:
    im going to say 37.25
  100. Ramiro Says:
    16,98 Kg / 37.43lbs
  101. Rob Witherspoon Says:
    38.6lb
  102. Collin Says:
    37.058 lbs
  103. Matt Lay Says:
    37.3
  104. Tom C Says:
    36.92 lbs
  105. Karupshun Says:
    32.7 fully DH’d out. I didn’t read the part using DH tires too :)
  106. theo Says:
    36.85 fo sho
  107. John Schoenrock Says:
    37.3972lbs
  108. Marc Says:
    my guess is 35.4lbs
  109. tony d Says:
    38.2 6lbs
  110. Matt Holland Says:
    37.36lbs
  111. ivan baria Says:
    17,7 Kg. / 39.02lbs
  112. Jun M. Says:
    39 lbs I’d say
  113. Mike Moore Says:
    41.2 lb.’s
  114. E2 Says:
    I’d have to say that since we’ve built a couple around 34- 35 lbs it would not be unlikely for it to be that light. So I guess I will say it will be 36.6 lbs.
  115. Lora Says:
    35.65 lbs
  116. xxFRESHxx Says:
    35,715 lbs
  117. Dan Says:
    40.2 pounds since you actually use a scale that works.
  118. Kieran Says:
    Just make sure the Blindside gets done first eh?
  119. Osman Says:
    38.9 lbs
  120. mbjosh Says:
    36.9 looobs(lbs)
  121. JackWho Says:
    36.72 lbs
  122. Scott Barnard Says:
    What size is the frame?
  123. alex is Says:
    39.5
  124. sicklines Says:
    Scott, it is a large
  125. mtec5 Says:
    36.3lbs
  126. Karupshun Says:
    LOL at the people guessing in the 40+ range…
  127. Kyle Says:
    37.4lbs
  128. Neil Rose Says:
    38.14 lbs Does so com come in Raw only?
  129. sicklines Says:
    You can get it in all the colors intense offers. Check out their website to see them all.
  130. Stint Says:
    My guess is it will be 17.410 kgs / 38.38lbs
  131. Sam Says:
    I’m guessing 37lbs
  132. Kenneth Says:
    I guess 36.2 lbs for the complete.
  133. Stefan Kühnen Says:
    I guess 16,3 kg / 35.93lbs
  134. Ewan Says:
    38.18 lbs
  135. Orlando S. Jimenez Says:
    36.4 lbs
  136. Scott Barnard Says:
    Thanks for the size info!
    Can you measure from the center of the bottom bracket to the top of head tube for me? Thanks!
  137. woody Says:
    38.27
  138. marcel schlueter Says:
    35.9 lbs :)
  139. packeteer Says:
    37 lbs……
    for DH thats good for women and small children.
  140. hn lee Says:
    16.25kg / 38.83lbs
  141. Division26 Says:
    38.4 LBS
  142. Mike Chin Says:
    36.83 pounds is my guess
  143. pocgnikcuf Says:
    38.235
  144. Ahat Says:
    i guess 38.7
  145. Zack Says:
    37.61 lbs
  146. Andre C Says:
    36 lbs
  147. cjw Says:
    36.11
  148. gilmazor Says:
    Hmmmmm… let’s say 16.85 kg
    good luck all of us :)
  149. Alex Says:
    16,100 kg / 35.49lbs
  150. Ohad Oded Says:
    17.6 KG
  151. EliadOded Says:
    16.7 KG
  152. DrJ Says:
    38.2
  153. ph Says:
    17kg / 37.48lbs
  154. okie_calvin Says:
    38.666 lbs!
  155. Marty on the bike Says:
    39.3 lbs.
  156. Bob Says:
    38.85
  157. Yamm Says:
    34.7lbs
  158. Osc Says:
    38.25 lbs
  159. Andres Avelar Says:
    38.35 lbs
  160. Ryan Says:
    39.8
  161. jiggrack Says:
    15.5kg/34.1 lbs
  162. Greg Says:
    37.85 lbs
  163. Dustin Says:
    37.08
  164. Jason Says:
    33.7 lbs :-D
  165. Sean Allison Says:
    I ‘m guessing 40.1 lbs thanks!!!
  166. Justin Gray Says:
    39.83 lbs
  167. o.s. Says:
    33.5 lbs
  168. stu Says:
    39.9
  169. Marc Schofield Says:
    35.8 lbs
  170. Ben Ritchie Says:
    38.24lb !
  171. Jason Foster Says:
    36.4
  172. bill Says:
    39.55 lbs!
  173. Steve Says:
    38.21….ignore first
  174. sky Says:
    36.72
  175. alex Says:
    16.47kg / 36.3101lbs
  176. Ian Says:
    37.12 lbs
  177. Ron Says:
    38.9 lbs
  178. Jean Says:
    35.8 lbs whit no xc parts and avid code ! I did
    it !!!
  179. Todd Onsorge Says:
    36.72 pounds
  180. jeff luque Says:
    34.75 lbs
  181. Nur Himawan Says:
    33.3lbs
  182. matt b Says:
    what is the new head angle for ‘08? and is the bb height changed?
  183. Paul S. Says:
    37.4 pounds.
    (.1 pounds lighter than blindside)
  184. Keeny Says:
    34 pounds
  185. tarka Says:
    36.68 # or 16.64kg
  186. Ray Says:
    36.9lbs
  187. Michal Says:
    36.1
  188. sicklines Says:
    Entry is closed now for guesses. Winner announced this Friday (04/04/08). :)
