Categories
News Submission
admin@sicklines.com
Shimano XT Wheelset WH-M776
Monday, November 5th, 2007
For Shimano’s 25th anniversary, they’ve created a new XT UST wheelset that is significantly upgraded from last year. The WH-M776 wheelset is aimed at the All-Mountain folk that want a strong wheelset that can take a little bit of abuse. This wheelset is a disc 20mm front wheel and a 135mm QR disc rear wheel but it is also available in a more convetional quick release front and rear as well as a v-brake version. See inside to learn more.
The 2008 XT hubs received an overhaul similar to Shimano XTR’s hub from last year. They have been upgraded to give this XT hub more engagement (36 pt or every 10 degrees).
WH-M776 front wheel (click to enlarge)
WH-M776 rear wheel (click to enlarge)
20mm front hub detail (click to enlarge)
rim, spoke, and nipple detail (click to enlarge)
Center Lock rotor detail (click to enlarge)
Shimano XT WH-M776 wheelset (click to enlarge)
The Shimano wheelset still works with loose ball bearings (36 front, 20 rear). This wheelset is disc only and uses Shimano Center Lock rotors (or use standard 6 bolt rotors if you purchase an adapter). It would be nice if shimano offered an option/upgrade to allow for 10mm thru-bolt rear axle as well. This wheelset comes in at a very good weight and is tubeless ready to save you even more weight. Look to see these wheels on a build in the future as they’re a good set of hoops that pack a lot of features.
[Shimano XT WH-M776 Wheelset Gallery] [Shimano Website]
3 Responses to “Shimano XT Wheelset WH-M776”
  1. Adrian Alexa Says:
    The new XT wheels are ACE. With every day passing I’m more and more glad that I purchased them. You can read my review on them here:
    http://forums.mtbr.com/showpost.php?p=3610328&postcount=13
    It is too early to comment on their durability, I only have ~250km on them. Lets see how they will do after one year of beating. Anyway, given that the XTR 07 wheels got rave reviews and the XT Shimano hubs always performed I don’t see why this wheelset will not.
    Just to add a bit more to the lines to the review from MTBR. The wheels accelerate instantly. I thought I will need to pedal a lot harder than on my HT bike, but I was wrong. Even with heavy tires (the front Bonty is at ~850gr and the rear is a Michelin HOT S FR at ~760gr) the bike is so easy to pedal. I think the rim is very light which makes for a less rotational weight.
    I love the wheels till now.
  2. okie_calvin Says:
    they sure are purdy!
  3. sicklines Says:
    Only until they get some mud on em :D
