Twenty6 6 Foe Pedal
Tyler has been hard at work designing his Twenty6 6 Foe pedal. They have a lot of unique features to them and aims to challenge what he feels is necessary in a pedal.
The pedals he sent along were test ones, so they did have some blemishes on them but you should be able to grasp what the pedal has to offer.
The pedal is very lightweight but it’s not cheap. If you’re seeking a budget lightweight pedal, look further, as this pedal isn’t it. The pedal offers many options for varying pin placements to fine tune your setup. Tyler’s packaging also included a english allen wrench that is needed to install/move/remove the pins. The pedal is flat and uses varying pin sizes included to setup the traction to gain a better grip instead of relying on concavity.
The pedal as you can see is not a parallelogram and Tyler feels that it works well. The pins thread in from the underside so its easier to remove or modify pin placement. The pedal is not offset, so you can’t setup the pins to be 100% the same on each side.
- Thin profile for clearance and a solid feel (95mm x 90mm x 18mm)
- 6061-T6 CNC billet aluminum pedal bodies
- Oversized 6al/4v titanium axle
- ABEC-3 Bearing
- Self-lubricating oillite bronze bushing
- Customizable & replaceable pins – 21 available threaded pin placements per side
- Each pair of pedals comes with 20 extra 1/4″ pins for replacement of the originals if they are damaged and 20 extra 5/16″ pins for height adjustment
- Designed and manufactured in the USA
- The 6foe pedals weigh in at 373g per pair and come in eight colors: Black, Blue, Green, Orange, Pink (pictured), Purple, Red, and Yellow.
The pedals will take a little bit of time to break in properly and Tyler has a few additional ideas for future pedals. These pedals aren’t cheap at $264.99 MSRP and definitely aren’t for everyone but if you’re interested in getting a set visit Twenty6products.com
