2008 Race Face Diabolus D2 Stem
If you’re looking for a new stem for your ride and you like your parts designed and built on this continent Race Face’s Diabolus D2 stem might be for you. We got to check out Race Face’s updated and revised 2008 Diabolus D2 stem. To find out more info on the D2 click the link below.
With the likes of Darren Berrecloth and Paul Basagoitia riding for Race Face you know their products have to be designed to hold up to some extreme punishment. Race Face is continually updating, modifying, and redesigning their products in order to meet the increasing requirements of strength and performance brought on by the evolving sport of mountain biking. The D2 stem is no different. For 2008 Race Face has continued to hone the D2 stem, making it better than before.
The D2 stem is designed to be a performance freeride stem that not only can handle big hits and punishment but also doesn’t weigh a ton. Each D2 stem is machined in British Columbia from 6061 aluminum. Our 31.8mm x 50mm D2 weighed in at 254g.
notice the hollow construction (click to enlarge)
Race Face has designed quite a few features into the D2 in order to make it perform well. The interlocking U-shaped handlebar clamp uses four bolts in order to secure the bar. Race Face also created a faceplate that eliminates “stress risers†which cause your bar to bend or break.
- Bar Diameter: 31.8mm
In order to secure the stem to the steerer tube Race Face used opposing bolts for the steer tube clamp in order to provide maximum clamping power while reducing stress on the steerer tube. The rear of the stem is also rounded in order to save your knees from getting hurt and scraped. Race Face makes the D2 for both 1 1/8″ and 1.5″ steerer tubes. More details are outlined below.
- Size: 35, 50, 70mm (1 1/8â€) | 50, 70 mm (1.5â€) - available in 0 Rise Only
- Rise: 0 or 10º
To find out more about the D2 stem, check out Race Face’s website. You can also view more pictures in our gallery.
