Avid Matchmaker
The Sram Matchmaker was designed by Sram to remove some of that clutter on the bars. If you’re running full Sram gear, check out what the Matchmaker has to offer inside.
If you’ve ever wanted to clean up your bars, Sram might have a solution for you. The Avid matchmaker adapts all split-clamp avid hydraulic brake levers to attach directly to Sram X.0 (and 2007 and later X.9) trigger shifters onto one mounting perch.
The Matchmaker is sold as a set for left and right brake/shift levers and while they won’t save any weight over having two clamps, they do significantly clean up the bars and offer a more seamless look and feel. Installation was a breeze and if you’ve got compatible hardware to run the Matchmaker it is a good investment to add some cleanliness to your handlebars.
No matter the discipline, the Matchmaker can probably make your bars less cluttered. Dirt jumpers should love this product as it’s a lot easier to use shorter bars since there’s just one clamp needed as well as more real estate on the bars to grab freely. The Matchmaker can be setup to have the shifter either inboard or outboard of the brake levers.
They offer ample adjustability so they should fit almost everyone’s style, so long as it’s not too far out of the norm.
Matchmaker Mounted Up (click to enlarge)
