2008 Sram
Sunday, April 15th, 2007Acadian over at Pinkbike has some good information on some 2008 Sram goodies. Check it out.
“The Vivid uses a one piece body which allows RockShox to reduce the amount of o-rings by eliminating a major seal that other manufacturers have up in the upper body. They also went with a large steal head bushing that maintains stiffness and allows for larger side loads.
RockShox uses their own special “shock specific” damping fluid. A damping fluid that is specifically designed for working under the high temperatures and pressures of rear shocks. You will also be happy to hear that the Vivid will be totally shop serviceable - yay!!”
Rock Shox Vivid
[more]
