Hayes Stroker Update
Friday, April 6th, 2007Earlier this week, we posted some information on the Hayes Stroker. We’ve got some more information for you from the Hayes stroker press release.
The Stroker will come in 3 models:Trail, Ryde, and Carbon
See more inside.
The Hayes Stroker will come in three variants for different applications.
There will be the Stroker Trail, Ryde, Carbon spec sheet here
The anatomy of the stroker master cylinder (click picture to see the details)
If you’re looking to see what the Stroker has done in detail from the Master Cylinder, Brake Pads, Caliper, and Ergonomics, see here
[discuss]
- Hayes Stroker Information
- Hayes takes over Answer Products
- Hayes Interbike coverage
- Sun Ringle Interbike coverage
- Answer/Manitou Interbike coverage
April 6th, 2007 at 2:45 pm
they will be Hayes’ high-end brakes, right? what is the 2nd graph, “Bladder Capacity”? is the amount of fluid that runs in the brake lines when you brake?
April 6th, 2007 at 2:53 pm
I don’t know for certain if these will replace, or what the situation will be exactly but these are definitly better higher end brakes than their current models.
Bladder capacity is something pretty key with Hayes brakes. If you’ve tried hfx9’s, they tend to heat up and fade a lot faster. People who suggest hayes for DH applications always suggest Mag’s since the lever of the mag has a bigger bladder and doesn’t fade nearly as fast since the fluid expansion of the mag’s is better since the bladder is bigger (along with a nicer lever).
The key difference between the Hayes mag/9’s is the all in the lever (caliper is the same between 9/Mag). The Mag lever’s have a lot bigger bladder than the 9’s so they can deal with fluid expansion a lot better. These new models from Hayes are even better than the mag’s in terms of specs
April 9th, 2007 at 1:05 pm
I’ve been really unimpressed w/ hayes brakes, from the HFX to the El Camino. I look forward to testing a pair of these out… hopefully they have been able to leverage their other companies to bring a new and innovative product to market.
December 20th, 2007 at 7:26 pm
At a quick glance it looks like there’s ~30% more pad area in the Trail & Carbon over the Ryde. This probably accounts for the better stopping response. That’s promising.
