Last month I showed you a sweet brakeset that I’m sure you drooled all over.
This next update I’ve taken a few pictures of the complete setup on the scale showing you just how light this setup is since I’m sure a bunch of you are still in doubt. I’ll make believers out of you!
Inside there are pictures of stock Juicy 7’s and the brakeset I constructed with the Avid Code caliper and Avid Ultimate Lever on the scale.
So here’s an update on the weight. As stated earlier, these weigh pretty much the same as Juicy 7’s. Both brakes below are cut to the same length. Both brakes below have no adapters and this is just the basic weight of each brake before including the adapters and rotor.
Avid Juicy 7 : Hose Length 1294mm
Avid Ulitmate + Code Caliper : Hose Length 1294mm
So there ya go. 3 grams off Juicy 7 weight. Pretty “Sick”.
Interested in a set? Send an Email
[discuss]
