How to: Overhaul a Hadley Rear Hub
Hadley doesn’t have a website and I’ve been meaning to take mine apart to give it some TLC in the off season. I got a hold of some Enduro Ceramic Hybrid Bearings to put in my Hadley hub to thank it for all the hard work its put in. Below you can see a tutorial of how to not only take your rear Hadley hub apart and overhaul it, but outfit it with some of the best bearings in the business, Enduro bearings.
[more]
I read your great article on rebuilding the Hadley Rear Hub. Question: the bearing model listed (6804) does not exist on the Enduro Bearing website. The 6803 and 6805 models are; but not the 6804! Was this model number a typo or was this bearing model discontinued?
Hey bob, its no typo. its the 6804 but isn’t listed on their website (they have more bearings than are listed)
contact chris@enduroforkseals.com and tell him you saw the article. He’ll get you the right one you need.
Hi: I appreciate your write-up on the rear hub overhaul. I would like to overhaul my front as well which is the standard quick release hub. Any chance you know the bearing size for the front quick release hub? Thank you.
Rich, I don’t have a front hadley hub. If you send me one i’d be happy to tell you though
I’d try calling go-ride, or hadley. They should be able to tell you
There’s that LOVELY “MADE IN USA” stamp.
You can’t go wrong with Made in USA!
Hi!
Do you know what the inner diameter of the 6804 bearings is? is it 20mm or 22mm ? Thank You!
Regards
